Turbo Action (and probably others) sold plates machined just like that.
If your buddy does it make sure he leaves a nice radius otherwise it will break.
If your rear clutch is apart look at that pressure plate - some guys install that one upside down in the front clutch to achieve the same thing. It’s tricky sometimes to get the snap ring in and out but it works.
