Got some runs on the chassis dyno today. Made 485 rwhp and 525 ft-lbs. Not bad for pump gas, hyd roller cam and cast iron exhaust manifolds.
Everything ran great on the dyno but there is some room for improvement. The AF ratio goes off at the start of the run so I need to work on the enrichment table.
