Shot of the data log for a dyno pull. The green line is the throttle position, the red is RPM. Pink wavy line is the actual air fuel ratio. The blue is manifold pressure and if you look close you can see that it drops slightly as the rpm goes up which shows that the throttle body is a bit of a restriction.
