Fuel system: All efi fuel systems should be a return type.
TBI vs mpi Multiport helps with cold start because the manifold is dry. It also eliminates distribution issues. Allows individual cylinder adjustments. Gains hood clearance because MPI TBs are shorter. Almost required for high boost applications. But in most cases there is very little difference in a street car.
