The dual sync distributor should work well with the Sniper. I'm waiting for the new Hyperspark ignition stuff from Holley to start showing up. The Hyperspark is all designed to plug and play with the Sniper so it will be a clean install. The dual sync is a pretty clean install though and it is Hall effect so that is better than trying to use a MSD distributor.
