There are no tricks required to getting a stock stroke 440 powered b or e body to run solid 11's if you can do whatever you want to get there......meaning, traditional hot rod stuff.
Intake, headers, slicks, converter, etc.
But..... If you plan to compete in the FAST or F/S series, then the car must be built within the rules...... Meaning no headers or slicks or intake manifold(not a concern with a 6bbl).
It is more of a trick to run 11's with a stock stroke 440 in a b or e body when you have to run exhaust manifolds and bias ply re-pop tires.
