Quote: 5.The 340 T/A and 340 Six Pac hoods were designed and built at the above mentioned studio.I worked on that project (at least 10 different versions) while we waited for more 70 Hemi e-bodies.
Did Creative have a Canadian location?
Not that I knew of but they were around until the 90's.Creative was a full service company that could do almost any type job for the OEM's.They had complete machine shop,wood shop,design,styling and engineering and more.
OK.....
So, if your statement - "The 340 T/A and 340 Six Pac hoods were designed and built at the above mentioned studio." is true, can you explain why the T/A hoods were stamped MADE IN CANADA?
Several original lift off RR hoods I have had were also stamped Made in Canada.
