BIG dollars but it costs a lot less when you do the work yourself and sure gives you a good feeling in your belly. I'm not big on DYNO numbers but even unfactored numbers got to be sky high. GREAT job Brett. I think Josh (monster Mopar) better start closing the giveaways to these small blocks. They are great engines with heads flowing better or very close to all the available big block heads.
