If you read the internet and listen to guys at the track...........there is a swinging dick on EVERY street corner with an inline valve, wedge smallblock, that makes over 900HP. I have been doing this stuff for a LONG time and have NEVER seen one, be it a Ford, Mopar or Chevy. As I said, you can do it with some canted valve stuff, but it's still not REAL easy and will be at a min of 40K if you do it with all new stuff.
I have done several 434ish Chevys and Fords, with the BEST 15-18* heads you can buy. A good one will make between 840 and 880, depending on cam, compression, rotating weight, etc. I have yet to see a Mopar head that was BETTER than the best off brand, so I am going to say it can't even realistically be done with an inline head........regardless to what some dyno sheets may say to the contrary
we'll I always in joy or input always controversial and backed by a lot's of personal experience how ever only making 840to880 shows your lack of engine building experience Prostock truck ran an inline valve W8. And there are many many many comp eliminator Motors that have all achieve 900 + horsepower with an inline head
Jesus H Christ......does nobody even READ the damn posts. I implicitly said that Pro-Stock Truck and Comp motors were NOT in the discussion, because they are in a whole nother world. Was talking run of the mill, single carb, real world motors, with 15-18* wedge heads, like most people build.......NOT 10,000 rpm motors, built for clutch cars or motors for 1400lb roadsters in Comp eliminator
Seems impossible on this site, for anyone to take anything within the context of the ENTIRE discussion. They want to take ONE thing you said in ONE post, run with that comment and ignore everything else.
You guys carry on...........I'm out
you said Ozzy Pro Stock and comp you never said anything about pro stock truck unless I missed it
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
