haha....did a comp test on #1 again......up to 130 now.....whew hoooo!!
So I think i'll do another treatment of Seafoam and get some tank and crank conditioner. Drive for a while to run it. I think I'll be fine.
Now got that 1413 800 on and tweaked it a bit with near perfect readings. Still a bit rich at idle, but better. Of course the primary to secondary hesitation, but that can be worked out. Carb works.
Now with that Slayer 750, should come out the gate well......
Unless anyone has anything to add, I think this case is closed.....thanks guys!!!!
--Mike
