I took my heads to my cylinder head guy today and I noticed that the new version of MW Victors looks like the valve cover rail is raised more than my old castings. When we measured the old to new castings, the new ones appear to be about 0.100" taller? The reason it looked different was because we were looking at how the rocker stands were milled off for the max wedge rocker shaft blocks.
We looked at some valve spring options and longer valve options. He is going to check with PAC to see if they may have a spring that could work that is not listed in their catalog. He was also going to check the cost of custom length valves. The slightly longer valves and raised rocker shaft does move the rocker arm roller towards the outer/exhaust side of the valve tip, bit the pattern is not too bad.
He does have some PAC-1326 springs that I could get a good discount on.
