Quote: What is the offset on the H&S rockers? I think the ones for the INDY heads are 0.800"? My T&D rockers for the MW Victors are 0.725" offset, and I think the standard port Victors are a 0.600" offset?
HS Intake offset for the standard or MW Victors is .650" I am running MW. I'm also using Comp 87019-16 lifters with .210 PR seat offset on intake. I hindsight I should have used the standard 829-16 solid body lifters and just done a little more clearencing for pusrods.
