The bolts I used were from McMaster Carr:
http://www.mcmaster.com/#90281a636/=w52oaz
http://www.mcmaster.com/#90281a638/=w52obb
Just for comparison, I noticed the strength rating on those studs are only 125,000 psi vs. what Hughes sells (I know, those are too short) that are rated at 170,000 psi.
Don't know what ARP's studs are, but I'd be curious if that 125,000 psi level is strong enough, considering the spring pressure you're going to run.
