Now to my question...why?
Uhhhh... 'cuz somebody effed up?
I'll check my Hughes offset intakes & standard exhausts and see if there is a similar issue, but I don't recall noticing anything wrong when they've been mocked up on a head before.
Just spent some time giving my Hughes rockers (1.6 offset int, 1.5 offset int, 1.5 std exh) a close and mine are all consistent w/ respect to roller pivot location. They all look basically like your offset intake, not your exhaust (which appears to have had the roller pin installed too low in the body).
