Cheatham-
Could you tell me a little more about tour build? I'm all ears and a double chin!
Muscle Motors did my shortblock, flat tops .010 in the hole Ross piston cut for B1 or indy head, the rods and crank are a china brand id have to look up the name but Mike at Muscle Motors has enuff faith in them for what im doing then I have no choice but to rely on it, Heads are 57cciirc and .051 cosmetic gaskets = 15-15.5 compression Bullet solid roller custom grind 7000 rpm max, oil thru pushrods, Jesel rockers, SV1 alky carb, B1 heads I bought used from a member here and were already ported and in the 400cfm range, 727 tranny with CRT internals where needed car is a 73 dart lightened and 4.10 gear converter is a 4800 8in, foot braked, right now im working the coilover mounts and waiting for custom valved front coilovers to arrive, hopefully here soon I can get it finished up.
Cheatham-
Read the last few posts( Its referring to crank sizes), and give your opinion too please
Greg
Cost is irrelevant, making memories is far more valuable!biggrin
