Headers are 2 1/8 to 2 1/4 with a set of Dynomax collector mufflers.
Where might one find side exit headers and that size? The ones that poke out thru the side of the fender.
http://www.bobmazzoliniracing.com/shop#!/~/product/category=4308142&id=21205906
2" to 2 1/8 step with a 3 1/2" collector. Also Hedman Hustlers. I have a new set of the Hedmans if you are interested in those. I will be using the Mazzolini/TTI pro parts headers instead.
Or you can buy the smaller flange from Indy and get a set of 2 1/4 or 2 3/8 tube headers made. I believe that is what MoparAl has in mind after he bought the flanges I had. He is also building a B1 572.
