Not Al, but if you're starting from scratch, go 604" 4.750 x 4.500..
Why not, you don't want to rev it up..
Chris..
Hi Chris'sBarracuda-
I ordered a KB block. I don't think it has the clearance for a 4.750 crank. Maybe a 4.625 at the most. Then it also becomes harder to find parts. I was trying to not get greedy on the size. Also keeping it some what maintenance free. As much as possible anyways.
Most likely it does clear.. The cam would be the only place it would be close. Guys do it all the time with KB Blocks..
It might even be possible with aluminum rods.. Just use 2.200 rod size..
Chris..
