I go the heads off today. Took a little work getting the intake off. I really had that sucker sealed. Everything looks good with the cam. Tops of pistons look fine too. All the lifters are fine. I think it was just that one valve. I wonder if the previous owner didn't glue the damn thing on before he shipped the heads. Anyhow, I am going to redo the heads and hopefully have it all back together in a week or two. A shout out to Doug's headers. I installed mine while I had the K member out so wasn't sure how easily they would be to install wight he motor in the car. If removing them was any indication, installing should be simple. Also, Bouchillon Performance for their AC compressor brackets. I was able to remove the intake and heads without removing the compressor. Save a bunch of time and effort.
