I'd check preload before I did anything. rocker arm geometry/wipe pattern would be a good idea also. get a junk hyd lifters or 2 & lock it solid to make a checking lifter out of it. I like to lock the cup .030" below the snap ring to simulate actual conditions, picky but I'm anal
