Your low beams should stay on when you hit the high beams - that is why the low beam headlight has 3 connection points : 1) ground, 2) low beam, 3) low beam with high beam
If the headlight goes out with the low beam, check the bulb . . . probably bad filament for the high beam circuit.
Cheers
Mark
The low beam bulb has two filaments, one for lows and one for high. So it should turn off the lows and turn on the highs when the high beam is selected by the dimmer switch. IOW, in high beam mode you should have all four lights lit up.
They say there are no such thing as a stupid question. They say there is always the exception that proves the rule. Don't be the exception.
