Quote: I would double check with a voltmeter to see if the voltage goes away at the switch. The wiring sockets for the switch are notorious for corroding with all the tracked in water and snow that soaks in there. Make sure they are clean. Also, this would not be the first time a defective switch made it into the marketplace.
Craig
I did check the wires and connections for corrosion that go into the high beam switch/dimmer, they all looked good from what I could see.
When you say check to see if the voltage goes away at the switch, you mean at the wires that connect to the high beam switch/dimmer, correct?
