I first went to the connection by the battery as that was the easiest to get to. The connections were all gummed up. I cleaned them the best I could put some dialectric grease in there and now...
When I activate lights the high beams go on , BUT should the lows go off or stay on?? I haven't had a car with 2 lights on each side in a while I can't recall
