69 Charger.
Didn't understand what you meant by mind the colors?
Are there wiring diagrams available on mymopar?
My bad I meant to say find the colors. yes, click on mymopar tools/reference then scroll down a bit & click on wiring/electrical then click on mopar wiring diagrams then click on the group that covers your year (69) then schematic A will have the rear half & schematic B will have the front half. I like to bring both of em up then I can click on either header on the bottom of my screen to easily pull em both up as that makes it easier to trace a wire as each schematic has a cutoff on the diagram. EDIT ohmed a 3 terminal headlight today & got 1.7 ohms side to side & 2 ohms from one of the side (parallel) terminals to the odd one & 2.2 ohms from the other side terminal to the odd one
