Quote: I have power on one side of the connector at the headlight and then on the other side as you switch from Hi to low beam. Even changed both headlights in the off chance.
If there's fire to both of the respective headlite terminals when you hit hi/low & the headlites themselves are good all that is left is the black (3rd) ground wire circuit
