Any chance that the large sector pitman-arms are slightly thicker in height perhaps?
I recall having used a manual steering pitman arm from a Dodge which fit the smallsector Borgbox nicely.
This mockup pic is with the pitman arm just pushed on the splines by hand;
for some reason the small sectors have no problems, I could check the thickness of the arms later,
curious if they are thicker, is there any harm in machining them down?
