I have the Firm Feel stage 3 on my 69 Barracuda, and it's good, except for the fact there is still some just off center numbness. For Autocrossing it's not ideal. I'm putting the Borgeson in my 67 Valiant because if it's anything like the newer Cherokee it came out of, it will be better...
Cars that are not reinforced in critical areas will exhibit the "off center numbness" regardless of whose steering box is in the car. The bigger the front tires - the more numbness you will experience under load.
Perhaps I'm not describing it correctly, but with my Firm Feel stage 3 box occasionally, not every time, you will turn the steering wheel one inch and get nothing, then two inches, nothing, then as you turn the third inch you get 3 inches of input all at once. It ain't tires or a lack of stiffness in the car, it's the steering box. Since it doesn't do it every time, it can make the car a handful in quick transitions. I'm going Borgeson....
