Re: Borgeson Stering Box
[Re: Uhcoog1]
#1519669
04/07/14 08:49 PM
04/07/14 08:49 PM
Posts: 1,491 Lethbridge, AB, Canada
dangina
can anyone with a large sector installed chime in? still no word from boregson.
Bumping this question again. No reply back from boregson
I've got the large sector. Don't remember which brand pitman I put on it, but it's a regular auto parts store part.
My engagement isn't much better than yours. I believe I had to thread the nut without the washer, cinch it up, pulled it off, then barely got the nut to thread with the lock washer. The shaft doesn't make it out of the nut on mine. Shouldn't be a safety issue, as it hasn't moved in 6 track days. Ya'll have me curious now if it could cause any bumpsteer issues.
Thanks for the reply - I had to do the exact same thing put nut on first, cinch it up, then pull it off to put the lock washer and nut back on. You can see in mine that the nut also doesn't make it all the way through, just glad to here that I'm not the only one, should have went with small sector, looks like the better fit
