Here I am sitting on a cinder block on the line at Hudson Dragway. Bill Hayes took the photo. Check out the "Tree" hanging from horizontal cables above me. If you get out of shape here, you really have a problem. Also notice that the shutdown area goes uphill. If that did not stop you, then the trees at the top would. If you somehow went through the trees, you went over the cliff.
