When you are spraying 400hp of Nitrous, quench is not effective, head gaskets aren't either.
In big nitrous hits, quench is too effective...motors make more power without quench and a few more degrees timing than with quench and low timing (that's what chamber softening is all about)...and without quench there's a bigger tuning window for timing....
Also, if you're spraying 400hp of nitrous on a 400hp motor and the long block/head gaskets would hold 800hp naturally aspirated, it will still hold 800hp when spraying...what kills head gaskets is detonation....
What's amazing is how good a motor runs while its detonating while being sprayed...
If you can't handle the truth, you're living a lie.......
