Quote: And With A Flat Top Piston, .100 Down, Would The Burn Be Better With Open Chamber, Or Closed Chamber Heads?
With the piston down .100 you want the smallest chamber you can get... its still gonna be a lazy burn.. a swirl port chamber would help it burn better/quicker
