I cant answer your question(I dont have the smarts or the experience)but I would ask what fuel, timing, cam and where its installed at.. also how hot do you run the engine at and what plugs you run... yes your correct that .040 seems to be the best point for it.. a thicker gasket can cause it to detonate even more (just like the low compression engines can detonate)
