I have talked to quite a few racers who use either Lucas ethanol fuel treatment or Seafoam fuel treatment as an additive to keep the gumming down. Most are turbo cars,blow thru and efi both. They complained about needing to clean injectors or carbs often. After using these products, they said the problem was greatly reduced. Just thought this info might be usefull.
