Quote: had a really bad dead spot I coulndn't get rid of,and seemed lean no matter what I did.
what kind of ignition? i had the same problem coming off the 2 step.
I have learned that more heat in the motor will help that problem. Only time I have had that issue is in the cooler weather.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
