Quote: had a really bad dead spot I coulndn't get rid of,and seemed lean no matter what I did.
what kind of ignition? i had the same problem coming off the 2 step.
I have learned that more heat in the motor will help that problem. Only time I have had that issue is in the cooler weather.
I don't know I have tried about everything you can imagine. come to find out the dig 6 is not recommended for alcohol/methanol and anything over 11:1 compression so that may be the problem. the volume of fuel may be to much for it to overcome coming off the 2 step for a split second.
