It runs fine when warm or sits after driving , have you changed the intake gasket? they are noted for their leaking also and it is a bit of a long shot check the bottom of the coil if mounted in the frt of engine if it has rust it is bad get another I have had more then my share of 5.2 and 5.9 engines that had that problem
