He needs to check for code 11 first in the computer. If there is a Crank or Cam position sensor problem this will drop the ASD/Fuel Pump relays and cut off power to parts of the igniton system and fuel pump, thus cranking and checking for voltage will show 0 after about 3 seconds. The fuel pump will not run if the computer does not see pulses from BOTH sensors.
Fuel Pump Relay Description and Operation
LOCATION
Relay is mounted in engine compartment, on the left inner fender.
PURPOSE
Relay supplies battery voltage to fuel pump and oxygen sensor heater element when energized by Powertrain Control Module (PCM).
OPERATION
PCM energizes fuel pump relay by supplying relay ground, when ignition switch is in START or RUN position and PCM is
receiving a reference signal from distributor. When PCM
does not receive reference signal from ignition system, (indicating engine is not running), then the PCM interrupts relay ground circuit and no voltage is supplied to fuel pump, ignition coil, or oxygen sensor heater element.
PCM controls fuel pump relay and Auto Shutdown (ASD) relay simultaneously, through same ground circuit.
