Is there any way to verify that the steering box is in the correct position? From what I have read, Firm Feel remounts the steering box mount to correct alignment and to help eliminate bump steer. Did you also reinforce or reweld the ends where the Kmember mounts to the frame? Thanks Tim
Quote: In summary, I just filled the open spaces where the steering box mounts were. I made patterns out of thin cardboard and traced onto the steel plate stock. When you look at a K member stripped down like this, you can see where there is room for improvement. They were probably never designed to last 40 years though! The bigger sway bars, larger brakes, wider tires ALL put additional stresses on the K member and frame rails. I'm anxious to get this installed and tested!
