Entry/Update Date: 1/27/2012
Model: Roadrunner
Year: 1968
Weight: Dry, Wet w/driver 3600lb Est.
Application: Show, Daily Driver, Drag, Autocross, Track, Race. Everything except for show
Engine Package briefly: 440, then a 383 and now a 6.1 based Hemi (Building currently)
Estimate HP: FW or RWHP
Trans: 23-Spline 833
Gears: 4
RE Ratio: 3.54
RE Type: SG Clutch type
Front Tire Size Brand Model: Yokohama Avid S/T 255/60/15
Front Rim width: 7"
Rear tire Size Brand Model: 275/60/15
Rear Rim Width: 7"
TB Dia: 1.22
Front Shocks: Koni Red
Front Sway bar Dia: 7/8" Factory
Rear Leaf Suspension Model Rate: Factory with 2" drop Blocks.
Shocks: Koni Red
Rear Sway bar Dia: N/A
Front Brakes: Factory Police with Firm Feel Carbon Metallic Pads
Rotor Dia Width: 11.75" Raybestos
Caliper-Pistons: Pin single pistons
Cooling Ducts: n/a
Rear Brakes: HP Drums stock shoes
Drum Size Dia Width: 11x3"
Parking Brake: Factory
Dual Circuit Dia MC: MP 15/16 E-berg Alum with AR Adapter Plate
Chassis: Firm Feel Stage 4 super duper top secret box, Firm Feel Greasable LCA pins, Poly LCA bushings, CAP UCA's. Poly Strut Rod bushings, AR LCA Braces, MP Steering Coupler Rebuild Kit, AR Tow Eyes
Subframe Connectors: MP Bolt in (welded)
Torque Boxes: n/a
Roll bar, Roll Cage: n/a
Aftermarket stiffeners:
Comments: Very happy with the over all combo. A lot has come to market since 08 though.
1. Best above improvement: Firm Feel Box
2. Least effective above improvement: WHeels and tires. The sizing is all wrong. Tires are betty than what I'm used to though.
3. Next improvement: Hotchkis Sway Bars and new rear leaf springs
4. Above car handles IMO on a 1-10 ( 10 best Z06, 1 yugo): 6. would be an 8 if I had 17" wheels and tires.
