Re: ATF4 in A833, good? bad? ugly?
[Re: mshred]
#1004004
06/23/11 10:32 PM
06/23/11 10:32 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
not to resurrect an older thread, but i feel i need some advice.
some of you have seen and replied in my other thread about my A833 grinding when i make the 1-2 shift under partial or hard throttle, but not under very light acceleration. I have taken the whole transmission apart and inspected every peice, and everything is working and worn as it should be with no visible issues at all. I changed the fluid in the transmission to AC delco synchromesh, and now im wondering my problem is the fluid im using?
Im thinking of trying ATF since i see quite a few people recommend it, and since its also dirt cheap and there is no non GL5 gear oil on any shelf here. Im wondering though what kind of ATF should I be trying? Dextron? Mercon? straight ATF? does it matter if its Dextron 3 or 4? Just looking for some input here since id like to refill the trans with ATF and see what happens
Forget that idea. Its not the fluid. Think about it, if it was an issue of the fluid(which it clearly isn't), then why only 2nd gear? Follow that logic?
Did you do what I mentioned for you to do in tn my previous post in this thread?
MB
Entire Thread
A990
06/01/11 12:06 AM
ademon
06/01/11 12:24 AM
FuryUs
06/01/11 01:00 AM
Pacnorthcuda
06/01/11 01:02 AM
A990
06/01/11 01:08 AM
ahy
06/01/11 01:32 AM
68LAR
06/01/11 01:45 AM
DJVCuda
06/01/11 01:59 AM
HPMike
06/01/11 02:08 AM
mshred
06/01/11 04:15 AM
cudaman1969
06/01/11 04:29 AM
rallye73
06/01/11 06:59 AM
Kern Dog
06/01/11 07:12 AM
azmopar
06/01/11 07:18 AM
gdonovan
06/01/11 08:33 AM
quickd100
06/01/11 11:17 AM
85_Ram_4speed
06/01/11 11:33 AM
ahy
06/02/11 02:49 AM
DJVCuda
06/01/11 01:09 PM
gdonovan
06/01/11 01:17 PM
JohnRR
06/01/11 01:28 PM
DJVCuda
06/01/11 02:02 PM
JohnRR
06/01/11 03:12 PM
DJVCuda
06/01/11 03:25 PM
76Beeper
06/01/11 06:06 PM
gdonovan
06/01/11 07:59 PM
Dean_Kuzluzski
06/01/11 08:19 PM
A990
06/01/11 09:21 PM
Blakcharger440
06/02/11 02:33 AM
mshred
06/02/11 04:35 AM
JohnRR
06/02/11 04:37 AM
mshred
06/02/11 04:46 AM
JohnRR
06/02/11 04:53 AM
ademon
06/02/11 05:12 AM
MoparKansas
06/02/11 07:03 PM
64dodge572
06/02/11 07:16 PM
GomangoCuda
06/02/11 07:36 PM
mshred
06/02/11 09:13 PM
64dodge572
06/02/11 09:25 PM
mshred
06/02/11 09:12 PM
Blakcharger440
06/06/11 03:51 AM
JohnRR
06/06/11 02:51 PM
Blakcharger440
06/07/11 01:18 AM
therocks
06/02/11 09:39 PM
JohnRR
06/01/11 07:11 PM
therocks
06/01/11 01:27 PM
DJVCuda
06/07/11 02:46 AM
rbkt65
06/07/11 04:51 AM
gdonovan
06/07/11 10:17 AM
mshred
06/24/11 01:34 AM
HPMike
06/24/11 02:32 AM
mshred
06/24/11 02:41 AM
ahy
06/24/11 03:49 AM
mshred
06/24/11 03:57 AM
John_Kunkel
06/24/11 07:15 PM
HPMike
06/24/11 07:37 PM
mshred
06/24/11 09:16 PM
68LAR
06/24/11 10:30 PM
mshred
06/24/11 10:57 PM
68LAR
06/25/11 12:35 AM
kilroy
06/25/11 01:14 AM
mshred
06/25/11 01:40 AM
DAYCLONA
06/25/11 02:59 AM
mshred
06/25/11 05:37 AM
zrxkawboy
06/25/11 02:31 AM
mshred
06/25/11 05:39 AM
zrxkawboy
06/25/11 01:10 PM
NANKET
06/24/11 04:03 AM
Joshs68
06/24/11 04:18 AM
70HemiGTX
06/24/11 11:24 AM
ThermoQuad
06/24/11 11:40 AM
68LAR
06/24/11 07:36 PM
DJVCuda
06/24/11 01:01 PM
cogen80
06/24/11 01:16 PM
DJVCuda
06/24/11 03:13 PM
Cab_Burge
06/01/11 02:05 AM
fourgearsavoy
06/01/11 03:28 AM
451Mopar
06/01/11 03:50 AM
kilroy
06/01/11 04:09 AM
John_Kunkel
06/01/11 06:32 PM
JohnRR
06/01/11 07:17 PM
DJVCuda
06/01/11 07:52 PM
CompSyn
06/02/11 10:56 PM
A990
06/03/11 12:30 AM
Pacnorthcuda
06/03/11 01:10 AM
A990
06/03/11 01:55 AM
