Here are some numbers from my car. Let me know if you want me to check anything else? I will probably have the dash apart this Winter to fix my fuel guage and ampmeter:
Car #225 RM23M9A Assembly plant sequential number 286687 Vehicle Order Number 949797 Line sequence number 289327 Gate 05 Sequence 136 EAD 6/3 Block 5/23/69 Carbs: 1139/4393, 1209/4392, 1219/4394-1 Door panels May 26, 1969 Alternator 69 .....<-( 5 spaces with dots filled in) Radiator 1299 Exh Man: L 5 26 (Rt has no date) Heads 05239 L, 05139 R Top Radiator Hose 38198-A (I did not replace it. It's on the car now along with the original P/S hoses and all the original vacuum lines) Motor Mounts: Both have 9..... <-(5 dots) K-Frame 15.9 1 Wiper Motor 1399 Starter Relay 189 Horn Relay 1329 Rear Housing 5 29 (See attached photo) RF Seat Adjuster #2935782 OK Tag dated 5/28/69 Wheels were 5 14 originally (I have 5 23's on it now but not original to the car) Lower control arms: 133 Left, 136 Right
