Thought this was April fools till i realised it's a few weeks away.
Plug INITIATES the burn , that's all it does , too cold a plug for the application 'may' leave a 'tad' power on the table due to unburnt fuel residing in base of plug , then you have too hot a plug 'may' leave a 'tad' power on the table due to mixure being lit off 'slightly' earlier , pretty 'negligible' which ever way you look at it.
Can you show us PROOF?
I have no argument with you or anyone else , the above statement ARE facts , WHICH PART DON'T YOU BELIEVE?'..........the way i see it is a guy changes plugs out & says it picked up , now were those autolites indexed exactly the same as the NGKs? , probably not as it would be impossible to do without indexing the first set , maybe he got lucky & the autolights just 'happened' to index themselves perfectly when installed (have we proof they were indexed the same?) , some guys claim the NGK picked up over the autolite ....................i'm willing to learn if you can tell me otherwise , legitimate question.
