nope, you dont have to buy 3 of them or odd ball parts,i threw the points/cond in the glove box..just like the instructions from pertronix said to do
few mins and it will be running agian
with lean burn,
swap carb also at that time
but to drop a points dist in,you just un-hook the negitive wire/side of the coil and hook the 1 wire from the points to negetive side of coil
how hard is that
thats the fastest way i know to ditch a lean burn system and on the cheap
to each his own,,but i like points and the pertronix conversions
never have used anything else
keep you ecu/pcm crap
