I had good luck with using no extra gaskets or sealer on the valley pan. I just shot both sides with several good coats of the permatex copper spray, did the rtv on the pan rails. Also had to use permatex thread sealer on the intake manifold bolts because a lot of oil was getting sucked up the threads.
That is all I did, that "orange" is RTV not paint in the pics above, bad choice.
They say there are no such thing as a stupid question. They say there is always the exception that proves the rule. Don't be the exception.
