Others disagree but I prefer to use the composition gaskets on both sides of the valley pan. I even superglue them to the pan the day before install--very anal about it, I create wood plates to clamp both sides.
Do you mean these?
I was thinking of using these but heard that they raise the intake up too high to get the bolts started...though I haven't tried it yet.
Yep ! Absolutely. Mock it up first to see if fitment is an issue, I've had good luck with 4 different intakes on 2 different 440's, One with milled heads too.
Would you use any sealer with the gaskets?
