i don't understand why when i hook up the hard line from the tank and put a hose from a gas can attached to the hard line bypassing my tank and sending unit, the fuel filter goes empty,
Oh OK I reread your post & yes you did that. I know you blew thru it but it's gotta have major blockage or sucking air big time (more likely the hoses if sucking air unless the hard line is real old in a humid climate (or salty gulf air). Might check it again (we ARE getting close (er) ) Whenever I get a straw w a minute crack in it w my McDonalds vanilla milkshake I get just enough to whet my taste buds then very little after that
