hey John,
i only replaced the line from the fuel pump outlet to the carb, i put a steel line in with a filter that connects to the carb steel line, i have not replaced the factory 5/16 hard line from the tank, the rubber hose connections i am referring to is the rubbert line at the end of the hard line from the tank and then the rubber line at the tank, so do you think i just need to replace the hard steel line from the tank?
