for a test, you can just loosen it. When it starts running crappy and the filter is nearly empty, walk back and loosen the cap. If there was a vacuum lock in the tank, loosening the cap should let it breathe and the filter should fill up again and the idle should smooth out.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
