Little update...
Checked what rpm on the converter stalls at. I got it up to about 3500Rpm before the rear tires got grip and started to push the car forward (3rd gear).. is this to low for the engine setup Im running???
Another problem: The engine also seems to "Bog" when I hit the throttle hard. Also a probable reason why my ET is not where it should be..
To cure the "bog" -Would a larger size squirter help? I dont want to change to many things at once... remeber Im a Noob!
/Tom
