I think I'll suggest to Randy @ MM to do just that - an article that compares 4 or 5 EFI systems and show the results. I already tested 7 systems but they were all on different engines. There's a missing point however; The engine dyno doesn't give you the feel that driving a car does, and it's those nasty transitions that you feel. I can get any system to run pretty good in a steady state.
You just nailed it. The Eddy unit I have now runs pretty good on the top and at a steady cruise but even after all the resources that I threw at it what you just said nails it. There are places on the throttle where it just SUCKS! -Bob
