Alright 195 stat in place eddy carb running fine slight hissing, but STILL OVERHEATING.
The fans are not yet functional but I only have water running through the block. I start to see steam coming from the radiator at about 5 mins of idle is the 195 to high of a stat or should regular coolant do the trick?
